Limited Slip/Posi Problems
Old Jul 10, 2009 | 12:09 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
How come the limited slip randomly dissengages in the car. It's a stock rear with 4.10s. If the car loses traction off the line it has a tendency to one wheel peel and when I bang into second it roasts both tires.
Can it be the fluids or is the limited slip on it's way out the door?
Old Jul 10, 2009 | 09:11 AM
big gear head's Avatar
Re: Limited Slip/Posi Problems
If you have the Auburn differentuial in a 10 bolt then it is probably worn out. You will have to replace it because it can't be rebuilt. If you have the 9 bolt Borg Warner rear end then the differential in it can be reconditioned at least one time. If you have a Governor Lock then you need to replace it with something that actually works.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
