Help me get a grip on my rearend.....sort of...
Old Oct 13, 2001 | 07:32 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
OK, we've got 9 bolts, 10 bolts, 9 inchers, 7.25s, 7.5s, 1,2,and 3 series carriers. I know what rear I have, but I'm looking for a better understanding of all this. I have and 88 with a 9 bolt 2.77 posi now, I have an 89 2.77 posi waiting, but now I'm thinking of going to a 10 bolt because of the larger range of options. Anyone know of a good source to learn what all this means(website, book, etc.) so I can figure out which way I want to go? Thanks to all.
ANYBODY but Gordon..
Ed Miller
Charlotte, NC
1991 RS, 305 TBI,
bone stock driver;
1988 IROC L98
TPIS Fast Pack, modified MAF, MSD 6A, Dynomax cat-back so far.
"Do you want to race or don't ya? I want to race." Dale Earnhardt
Old Oct 15, 2001 | 09:31 AM
ebmiller88's Avatar
ttt
Old Oct 15, 2001 | 12:58 PM
82camaro's Avatar
Car: 82 camaro SC
An excellent source is right here, what exactly do you want to know? A 10 bolt, 3.73 posi/locker, disk(assuming that's what you have now) rear end would really wake your car up.
https://www.thirdgen.org/newdesign/t...nguprear.shtml
http://www.isthq.com/~dan/10bolt.html
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Oct 17, 2001 | 06:27 PM
ebmiller88's Avatar
Thanks for the help
Old Oct 17, 2001 | 08:03 PM
ebmiller88's Avatar
I checked those pages out and they are great, but I guess what I need to understand is what is meant by 1,2,and 3 series carriers and what determines the size of ring gears (7.625, 7.5, etc.) I have no idea. Is it the type of rearend or the gearing? What carriers and ring gears go with what rears? I am contemplating switching my 9 bolt for a 10 bolt disc rear and installing a SLP posi and 3.42 gears. Thanks again guys.
Old Oct 18, 2001 | 09:08 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
The 7.5/7.6" number is the diameter of the ring gear itself (Ford 9" has a 9" ring gear diameter, GM 10 bolt 8.5" has a 8.5" diameter ring gear and so on) Someone correct me if I'm wrong but the carrier series I believe denotes the gear ratio you can use on that specific carrier. Example, Richmond sells 3.42 gears for a 3.08 and numerically lower carriers(2 series) and for 3.23 and numerically higher carriers(3 series) which are different part numbers. Hope that helps.
92' Camaro RS 305 TBI
Best 1/4 mile - 14.6 @ 96 mph w/NO NOS
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4860
Old Oct 19, 2001 | 07:36 PM
ebmiller88's Avatar
I get the ring gear issue but I'm still lost with the carriers. What determines them...year model? Manufacturer? How do you tell? Can a 2 or 3 series go in the same rear? Example, I guess I need to hear something like "This '92 Z28 has a ____-inch (ring gear) 10 bolt with a ___-series carrier, and this is why I know that.
Sorry if this seems monotonous but I don't get this yet. Thanks for the patience.
Old Oct 20, 2001 | 07:55 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by ebmiller88:
</font>
the difference between a 2 ans a 3 series carrier is the thickness of the flange the ring gear bolts up to. a 2 series carrier is not as thick on the flange as a 3 series carrier. the ring gears on 2.00 ratio are thinner than the ring gears for 3.00 ratios. you can put a 3.08 or higher numerical gear on a 2 series carrier with the aid of a ring gear spacer. however, most times you cannot do the reverse. because you would not be able to shim the posi over far enough. now, they do make aftermarket gears for the carriers. that's why they say 3.42 (2 series carrier) and 3.42 (3 series carrier) so you won't need to buy the spacer. hope that helps.
Old Oct 20, 2001 | 08:03 PM
mrr23's Avatar
Engine: 360 HSR
actually the split between 2 and 3 series is 3.08 and numerically lower is 2 series and 3.23 and numerically higher is 3 series
Old Oct 22, 2001 | 11:32 PM
ebmiller88's Avatar
THAT'S what I needed, thanks guys. Now I've got it.
Old Oct 23, 2001 | 12:27 AM
Momar's Avatar
does anyone know of any good places to get gears for the bw 9 bolt. I know that they are more expensive, but that is what I have and from what I understand they are stronger than a ten bolt. I have 2.77 limited slip in it now. I have a 3.08 gear also that came in my origional rear. It is also a bw nine bolt but it is open carier and had drum brakes. If it is too much trouble or costs way to much I may just use the 3.08s but I would like to run something more like 3.45s. Thanks for your help.
Old Oct 24, 2001 | 03:21 AM
ebmiller88's Avatar
Do a search. There's a guy here (88 427 Chevy?) who sells them, he can hook you up.
FYI, topic wise, I'm gonna stay with my 9 bolt and just switch gears when I get around to it. It's got the PBRs so I'm happy..
[This message has been edited by ebmiller88 (edited October 24, 2001).]
Old Oct 24, 2001 | 11:05 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by Momar:
does anyone know of any good places to get gears for the bw 9 bolt. I know that they are more expensive, but that is what I have and from what I understand they are stronger than a ten bolt. I have 2.77 limited slip in it now. I have a 3.08 gear also that came in my origional rear. It is also a bw nine bolt but it is open carier and had drum brakes. </font>
i don't think that was a 9-bolt man. 9-bolts never had a 3.08 gear and i don't think they ever came with drum brakes. You have a 10-bolt with that drummed 3.08 rear
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Oct 21, 2003 | 06:32 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
www.9bolt.com
they sell 9 bolt rear end parts.
Street Lethal
Apr 30, 2019 12:14 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
ctoledo0834
Sep 18, 2015 04:16 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Fox118
Sep 12, 2015 09:29 PM
