Swappin my axle for a posi with disk brakes
Old Jul 10, 2009 | 07:56 PM
ian1320's Avatar
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
I just scored a posi rear axle with 327 gears and disk brakes from an 89 iroc-z.
2 questions for the experts:
1. Four wheel disc optioned (J65) IROC-Z's rear brakes were increased in size from 10.5 inch rotors to 11.65 inch rotors with PBR Australian built aluminum calipers and more reliable parking brake actuators. How tough are the calipers to find or what can i replace them with and will my crappy 15" standard z28 wheels fit over those calipers? (I want to put original 85 IROC wheels on it but i have yet to find a set i would be willing to pay money for)
2. What else is required for the disk brake swap? is it just as easy as unhooking the brakelines from the drums and hooking up the disk brake calipers?
Thanks in advance for any advice. Ill be tackling this swap this weekend with a little luck.
Old Jul 11, 2009 | 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Swappin my axle for a posi with disk brakes
Originally Posted by ian1320
1. How tough are the calipers to find or what can i replace them with and will my crappy 15" standard z28 wheels fit over those calipers? (I want to put original 85 IROC wheels on it but i have yet to find a set i would be willing to pay money for)
1) Most automotive parts stores will have or can order PBR's. Since some latter year IROC's were equipped with 15" wheels, I'd guess fitment isn't an issue.
2) You'll need e-brake cables and a disc brake proportioning (combination) valve for best brake performance. Check the following site for the latter:
http://www.flynbye.com/
The line at the t-block is the only line you'll have to worry about, IIRC--that's assuming the new rear has lines and calipers in place.
JamesC
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
