tranny question.
Old Jul 12, 2009 | 09:18 AM
83camaro86's Avatar
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
tranny question.
I have a 83 Camaro. My question is does the tranny use vacume to shift? The tranny will sift if i do it manulay but not on its own. So do i need to run a vacume line to it? If so where to i need to run it from the carb? Thanks for any help
Old Jul 12, 2009 | 12:25 PM
transtalker's Avatar
Car: 95 Suburban K1500
Engine: 355 TBI,heads,cam,flowmaster exhaus
Transmission: 4L60E custom rebuild, mod shift kit
Axle/Gears: 3.08 front and rear
Re: tranny question.
what type of trans do you have in your car is it an overdrive unit or three speed in an overdrive unit your shifts are controlled by the throttle valve cable a cable that runs from your transmission to your carburator on the three speed units it is controlled by vacuum
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Ian Irvine
Sep 4, 2015 08:08 AM
