700R4 lock-up
Old Oct 22, 2001 | 12:47 PM
Josh75402's Avatar
700R4 lock-up
Do you have to hook up the wiring for the tranmision to work??Will it go into 4th gear or not??Will not hooking it up cause the transmission to fail??
Thanks,
Josh
Old Oct 24, 2001 | 01:28 PM
Pro Built Automatics's Avatar
The wiring is for torque converter lockup, I would hook it up to help out gas mileage, lower operating temperatures, less rpm's on the freeway, etc.
Old Oct 24, 2001 | 01:53 PM
Josh75402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Pro Built Automatics:
The wiring is for torque converter lockup, I would hook it up to help out gas mileage, lower operating temperatures, less rpm's on the freeway, etc.</font>
Thanks for the reply.What would be the best way to hook it up on a noncomputer controled car?The computer is still in the car but the fuel injection has been replaced with a carb.All the wiring is still there though.If I plug it up should it work or does it have a sensor on the engine that controls the lockup?
Thanks,
Josh
Old Oct 24, 2001 | 02:42 PM
Try it to see what happens.
Old Oct 24, 2001 | 06:29 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I am in the same boat. I just aquired a 700R4 and want to install it in a car that was originally equipped with one but currently has a TH-350. The wiring for the TC lockup is still in my car as well, but I also don't have the fuel injection system anymore. Mine is a non computer controlled carb setup. The computer is still in the car but I would like to know what happens to my trans if in fact the computer needs some kind of input from the engine end to work the trans correctly. Could this burn up the trans? how would I know that it isn't acutually locking up when it should be?
Old Oct 25, 2001 | 09:15 AM
Josh75402's Avatar
Yes you sound like you are going through the same tranformation I am.I pulled my 350 tranny out of mine when it lost second gear.Then I ran across an Iroc for a song so I pulled the tranny out of it to put in my 88 RS.I have put it in the car but have not hooked up the detent or lockup.I have put it in drive and reverse and seems ok.I will let you know if it works or not hooking it up.I think I may try it this weekend.Thanks for all the replies though.
Josh
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
