REAR AXLE PROBLEM HELP¡¡¡¡¡¡¡¡¡¡
Old Oct 22, 2001 | 08:44 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Guys i need help please i have a Firebird 82 S/E with 3.08 Rear...it started with a noise ..whn i took off the cover..i realized i broke the Drive pinion thoots¡¡¡¡ oh no my question is i have another rear from a 78 Malibu ..its a 2.73
will the Drive pinion fit my 3.08 ???
HELP ME GUYS THANKS ¡¡¡¡¡
Old Oct 22, 2001 | 11:36 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The pinion and ring gear are different in every gear ratio set. That is what makes them 2.73s or 3.08s.
No a pinion out of a 2.73 won't work in a 3.08 rear. (if I understood the question correctly )
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Oct 24, 2001 | 11:01 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
if it has the same number of teeth it should. provided they are both the same size rear. cannot put a 8.5 gear set in a 7.5 rear.
Old Oct 25, 2001 | 12:27 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
1) It won't fit because the tooth count is different
2) It won't fit because the Malibu is an 8.2 rear and the firebird is a 7.5 rear.
Just get a new ring & pinion. They are cheap for 7.5 10 bolts.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
