Auburn Pro Posi
Old Oct 24, 2001 | 07:51 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
Auburn Pro Posi
Folks that have it, do you remember how much slip modifier you've gotta put in , 4oz, or 8oz.
Its been like two years since i put it in, and, installing new gears, and i can't remember how much to put in, one tube or two.
Also i can't remember the spec for backlash, is it like .009-.015, or so? I don't have a manual handy and can't remember for the life of me.
Thanks.
It's always SOMETHING
[This message has been edited by Pony Killer (edited October 24, 2001).]
Old Oct 24, 2001 | 08:02 PM
Jay 727's Avatar
You can never have too much, usually 4 oz per quart of GENUINE GM friction modifier. Nothing else works right. I tried the cheap crap even 16oz of it, called auburn and they said they get at least three calls a week on that subject. Just thought I'd share that.
Old Oct 24, 2001 | 10:15 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The instructions should tell you how much backlash to run. My richmonds had the spec etched into the side of the gear. It is usually .008"
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Oct 24, 2001 | 10:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
.009" to .015" is good; with used gears I shoot for .010"-.012". I'd rather have a little too much (slight backlash) than too little (destruction). .008" like GMTech says is correct, for new gears. The gears get hot and expand when doing their job, so the clearance mostly goes away during driving anyway.
ICON Motorsports
Old Oct 25, 2001 | 12:29 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
If you have more than .002-.003 variance in backlash, something is wrong. Somewhere around .008-.010 is probably good, but it depends on the gear set.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
KO1
16
Oct 15, 2015 05:00 PM
loud91rs
Oct 5, 2015 10:05 PM
