Gear Swap(2:73 to 3:42)- Questions
I was thinking of swapping my gears to gain some quick off the line power but I want to find a good ratio to go with. Does anyone have a formula to calculate the gear ratio or RPM based on the following parameters: overall tire height, transmission ratio in each gear, rearend gear ratio? I want to find out what RPM I will be pulling in each gear and how this will effect my speed in each gear. I will be running 18" wheels so my tire height will be around 27" in diameter. I drive my car on the highway a lot so I don't want to sacrifice too much by going with 3:73 or 4:10 gears. Any help would be appreciated.
Thanks, Josh
Thanks, Josh
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Go look at the front page of this site, there is a bunch of tech stuff on the left hand side, including exactly what you want.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
use this
rpm = mph x gr x od x 336 / td
rpm = engine
mph = miles per hour
gr = gear ratio
od = overdrive ratio
336 = magic number that makes the equation work
td = tire diameter
rpm = engine
gr = gear ratio
td = tire diameter
