T/C lockup speed?
Old Oct 18, 2001 | 11:20 PM
88TAJeff's Avatar
Car: 88 T/A
T/C lockup speed?
I've been chasing a 'jerkiness' gremlin lately, and I thought it was the motor after my cam swap. It does it at very mild throttle 800-1500 rpm. It seems to only do it after the motor shifts into 3rd and the T/C locks up. Today, I left the shifter in 2nd, and it didn't jerk at all under any conditions until it reached about 40 km/h, and then it felt like the T/C locked up. Is it supposed to lock up in 2nd? This is when it started jerking again. Why would it be jerking after the T/C locks up? is it a bad connection causing it to lock/ unlock ? Please help, I know nothing about trannies.
BTW, it's a 700R4. Thanks,
Jeff
88 Trans Am 305 Auto Red/Silver, MSD coil,wires, ported plenum, gutted airbox, TB bypass, comp cams XR258HR, 206/212 @ 50 .480/.487 110 LSA everything else stock
Old Oct 19, 2001 | 12:07 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
There's a pressure switch for 4th gear in the valvebody that grounds one side of the lockup soilnoid when the trans is in 4th gear.
This isn't on all models, but if it fails closed, it will cause lockup in all gears except 1st.
Old Oct 19, 2001 | 12:14 AM
88TAJeff's Avatar
Car: 88 T/A
Thanks, Joel. doing a search on this, it appears the TCC will lockup under light throttle conditions in 2,3, and 4th. even or a properly working tranny. Is this true?
Old Oct 19, 2001 | 03:34 AM
transfixleo's Avatar
Yes.
Old Oct 20, 2001 | 12:04 AM
88TAJeff's Avatar
Car: 88 T/A
Ok. I know for sure now that my TCC lockup is the problem. When I'm in 3rd, and put the brake on a little bit, the TCC unlocks, and no more jerking. Lots of jerking when I take my foot off the brake again. It seems like the TCC is locking up when it's supposed to, so what would cause it to act like this. If it was a connection, wouldn't that cause it to sometimes not lockup?
Thanks,
Jeff
Old Oct 20, 2001 | 03:11 AM
Actually that is not normally true. What happens is and engine missfire shows up more when there is a solid connection to the engine, instead of the dampening affect of the unlocked converter. This is usually worse in 4th.
You can try power braking to see if you can reproduce it or probably better yet, put a vacuum gauge on the engine and drive the car. If when it occurs the gauge starts to flutter badly then it is the engine, if not it is the tranny/convetrer.
Old Oct 29, 2001 | 02:17 PM
88TAJeff's Avatar
Car: 88 T/A
Hi. I finally got my hands on a vac gauge. When the car is doing it's jerky thing, the gauge is rock solid. Does this mean the prob. is in the converter? this is the only time I notice it. I have never used a vac gauge before, I hooked it up to the plenum. Is this alright? Thanks for your help.
Jeff
seiplentz
Aug 19, 2019 06:02 PM
Elephantismo
Feb 13, 2019 12:51 AM
customblackbird
Oct 1, 2015 04:30 PM
Giocio
Oct 1, 2015 12:20 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
