How to do a pressure check on my 700R4?
Old Oct 30, 2001 | 03:36 PM
Dave M's Avatar
I need to do a pressure check on my 88 700R4. Can someone give me step by step instructions on how to do it, and what parts, if any, are needed?
Thanks,
Dave M
88 GTA
Old Oct 30, 2001 | 04:11 PM
transfixleo's Avatar
You will need a quality pressure gauge. This means Snap-On. Any others and you run the risk of making a BIG mess when it comes apart. You will also probably need some 1/8 pipe fitting adapters to get the hose on the side of the tranny.
Once you have this setup, do this: Check pressures in all ranges, writing down the readings. Make a column for idle, fast idle and fast idle with the TV pulled full. If you see in any range that pressures are not steady, put a check next to it so you know.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
g.l.mos
Aug 22, 2015 12:02 AM
spaigo
Aug 21, 2015 07:46 PM
BurlyChev
Aug 16, 2015 09:08 PM
