700r4 torque converter problem
Old Jul 18, 2009 | 09:36 AM
tom h's Avatar
Car: 1988 camaro z-28
Engine: built 350
Axle/Gears: 323 one wheel wonder
1 have a 400-450 horse 350 engine with a 700r4 trans. my problem is every time i put the car in gear it bucks shakes and stalls out. i was told the problem was the stall is too low. is this true? and if it is what do i need to fix the issue and after that can i lower my idle down to 750-800 rpm and be able to drive the car. now i have to double foot the car or put in neutral to drive the car any help would be appreciated thanks
Old Jul 18, 2009 | 10:33 AM
skinny z's Avatar
Re: 700r4 torque converter problem
Almost sounds like the torque convertor clutch is applied full time.You should be able to disconnect the wiring to determine if that's the case. Just a thought.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
