T56 SWAP Q'S
Old Jun 18, 2001 | 08:31 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
T56 SWAP Q'S
Those of you who went from 700R4 to the T56, did you use the automatics starter? How much shorter is the auto's drive shaft?
Any tips on the swap would be greatly appreciated.
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
Old Jun 18, 2001 | 09:01 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Look here:
http://www.sethirdgen.org/t56.htm
There is information about the starter and driveshaft.
HTH
Old Jun 18, 2001 | 09:43 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Lots of information I hadn't known!
On the automatic radiator, do you plug the cooling line holes? won't fluid come out if not?
Old Jun 18, 2001 | 10:31 PM
CHCKLS's Avatar
Engine: 409 SR
LOL.......You can drain the radiator of the fluid by taking the raditor out or use some king of vaccum pump or something or another to get the fluid out while the radiator is still in the car. When I did my swap I just let the fluid come out as the front end of the car was on the jack stands. It's going to be the least of your problems.
HTH
Old Jun 19, 2001 | 12:37 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
FROBOZZ-
What I wanted to say was do I need to plug the tranny line holes in the radiator after the swap to use the same radiator.
[This message has been edited by irocdaddy (edited June 19, 2001).]
Old Jun 19, 2001 | 11:04 PM
CHCKLS's Avatar
Engine: 409 SR
Sorry about that. No, you do not have to plug them.
Old Oct 31, 2001 | 11:59 AM
89Irocn2o's Avatar
Nevermind
[This message has been edited by 89Irocn2o (edited October 31, 2001).]
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
