HELP I NEED SPEEDO GEAR HOUSING FOR 45TOOTH GEAR!!
Car: 1986 Iroc z
Engine: 350 tpi
I need a speedo housing/aluminum that will fit a 45 tooth speedo gear. The black plastic one will only work wiith up to a 39 tooth gear since the 40-45 tooth gear is a bit wider on the shaft. I have looked everywhere i could here in my area and noone has one. PLEASE help.The dealer says its no longer available. I can but a new one for 70.00. on the tranny site online. used would be more sufficient for me I HAVE PAYPAL!!!
Car: `86 SS / `87 SS
Re: HELP I NEED SPEEDO GEAR HOUSING FOR 45TOOTH GEAR!!
there were black plastic ones for 40-45 tooth when I bought some years back. Prob. have one.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Have you tried installing the regular one? I saw everywhere that a larger housing was required, but I ignored it when I swapped my gears, and it fit just fine.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
for under $25 you can buy a new 45 tooth that comes with a new plastic carrier. this is detailed on one of my stickies.
Car: 1986 Iroc z
Engine: 350 tpi
Car: 1986 Iroc z
Engine: 350 tpi
Car: 1986 Iroc z
Engine: 350 tpi
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
