700R4 Converter and Electrical Lockup question
Old Jul 20, 2009 | 11:22 AM
mavcar38's Avatar
Car: 89 Iroc
Engine: 350 Carb
Transmission: 700R
I have done a conversion from TPI to Carb. The engine is expected to produce 360 hp. While I have it out Im going to go ahead and have the tranny rebuilt. What stall converter for the 700R4 should I get or should I just keep the stock. I will be driving the car a lot of the road. Dont plan on racing it yet. Also, do I have to do something to bypass the electrical bypass lockup swtich since I will no longer have an ECM or can I just leave as is. Thanks for all the help!
Old Jul 20, 2009 | 04:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700R4 Converter and Electrical Lockup question
When in the transmission, install a tcc lockup kit - the kit replaces a solenoid inside the tranny, and a few wires get redone, then you attach a vacuum switch to the system that locks the TCC for you (you can also install a switch to manually lock it).
MustangBeater20
Oct 29, 2022 09:20 PM
jklein337
Sep 19, 2018 06:23 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
