Is the t-5 or t-56 clutch better?
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I am most likely going to purchase a new manual transmission. I have a choice on going to an aftermarket t-56 that uses my stock hydraulics and clutch or a 4th gen t-56 with the pull type clutch. IS there any advantage to either??? Grip?? Durability? cost?
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
1991 Firebird
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The T5 clutch is better, because it is a standard NO BS push type clutch. I never had ANY trouble with it. The T5 is another matter.
The T56 clutch is a ROYAL pain in the *** . I haven't gotten mine working yet, damn thing simply won't disengage all the way. The tranny is a much better/bigger/stronger tranny however.
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I don't know which is better, but
i do know that GM Hi tech had problems with their t-56 clutch, and then had a little box that said "Why is it so hard to make a t-56 clutch"
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you go with the after market you need to get a McLeod special clutch, it is 10.95 (Still bolts to the stock flywheel) as opposed to to the stock 10.4. The pull type is 11.00, But to answer your question YES you can use the T-5 with the after market.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
tonys91rs
Oct 10, 2015 03:31 PM
