Cable to Electronic speedo adaptor?
So I bought an 88 T-5 for my 1LE this weekend. It has a cable driven speedo and my car has electronic (VSS). Who makes the adaptor for such an installation? Thanks in advance for any replies.
Go to AutoZone or somthing and ask them to PLEASE, PRETTY PLEASE order all of the possible VSSs for your 88 tranny and pick out the one that fits in the hole and buy it. I did that and it worked great.
BTW: Make sure you use the right driven gear. I would go to a GM dealer and double check the colors and maybe order the correct one.
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Gutted Cat, No muffler
Was 700-R4 --> Now T5
**** Great cars aren't bought, they're built ****
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Wait, what trans do you have now? If its a T5, just take your VSS from your trans and put it in the other one.
If you have a 700R4 now, then you'll need to get the new one from GM or the auto parts store, like above. Or check the classifieds, sometimes people have extra ones for sale.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Wouldn't it be a lot easier to just order the correct part number from AutoZone or GM ?? If you do a search on this board there's a post with the part numbers for it.
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Soon to be installed. WC T5 !
1991 Z28 5.7 TPI
I forgot to mention the year. What I'm trying to do is replace my 91 auto for an 88 T5. I know my 91 is an electric speedo and the 88 I bought is a cable driven. What do I need to do so my speedometer will function properly? Thanks guys
So can anyone help with the info on parts I'll need? I should be able to re-use my driveshaft, I need a new starter, x-member...I've swapped my pedal assembly. So for my tranny and speedo, what would I need going from a 91 auto/elec to a 88 manual/cable?? Thanks in advance,
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey Mubie, it seems as if FAITH has brought us together, I have a 91 WC T-5 with VSS, and I need a T-5 MECHANICAL SPEEDO assembly, do you want to just SWAP? It will benifit us both
88 Monte SS 355 TPI/LT-4 HOT CAM/Fully ported 1990 Corvette L-98 heads/AFR Hydra-rev/ T-56 6-Speed/ PRO-5.0 shifter/ 1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
