Question for you T-5 GURU's, about MECH speedo conversion on a 91 WC T-5
Old Nov 1, 2001 | 03:10 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hello guys, I'm installing a 91 W.C.T-5 in a friends 86 Monte SS, and I want to maintain the MECHANICAL SPEEDO feature of the car. I looked at the tranny, and it looks like the VSS sensor could just be removed and then just install an earlier T-5 mechanical speedo assembly. Am I right in this assumption? Thanks and please feel free to correct me if my assumptions are wrong .
88 Monte SS 355 TPI/LT-4 HOT CAM/Fully ported 1990 Corvette L-98 heads/AFR Hydra-rev/ T-56 6-Speed/ PRO-5.0 shifter/ 1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
Old Nov 1, 2001 | 04:08 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Correct. Just make sure the same drive gears were used for both. Visible once you have the mechanical speedo gear out. It should be the same color. Otherwise you'll need to swap it out.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Nov 1, 2001 | 04:23 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Thanks lonsal
lt1z350
Aug 28, 2015 05:57 AM
Cacike
Aug 27, 2015 05:10 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
