driveshaft length ??? 82-92 to 93-02
Anybody know for sure if a 93-02 Camaro/Firebird drive shaft will fit in a 82-92 Camaro/firebird--looking to swap an aluminum shaft in place of the steel one---fed387
Car: 1987 Black IROC-Z (SOLD)
Re: driveshaft length ??? 82-92 to 93-02
All Factory stock 3rd & 4th Gen Camaro/Firebird Dr Shafts (aluminum & steel for both Auto/Manual) are the same length. Does that amswer your question?? If not , do a search.
Car: check
Engine: check
Transmission: check
There are different length drive shafts in the 3rd gens. And the 4th gen driveshafts can be a one piece or a two piece unit.
Then dependent upon the year of the 3rd gen the rear U-joint will vary.
RBob.
RBob.
Why go off on a tangent, he did NOT mention anything about the 2-pc V-6 dr shafts. Also, I never heard any onyone have a problem with the u-joints on the 10 or 9-bolts. I sure as hell did not, when I used 1LE shaft on my 9-bolt
82-83 cars with a TH350 short tail did have a different length.
JamesC
Car: 91 Z28
Engine: LB9
Transmission: 5-Speed
Axle/Gears: 10-Bolt 3:42 Posi
OK...I have a question to ad to this thread. I have a 91 Z28 5-speed, 10 bolt. Which 4 gen shaft do I need....The LS1 shaft or the V6 shaft. Thanks in advance!
If it is not a cloned Z28, you have a V8 and can use the 3rd/4th gen ILE 2 3/4dia or the 4th gen LS1 3" dia Aluminum Dr Shafts. Forget about the 2 pc shafts used on V6 cars.
Car: 91 Z28
Engine: LB9
On the LS1 shafts....Does it matter if its auto or 6-speed?
I do not have a cloned Z28, its the real deal.
What is this standard or typical length? Mainly interested in shafts used behind a 700r4 or the T-5 or a 4th gen with a T56. If someone has the info or one happens to be laying around, or the car is already on a lift or you're going to be under there anyways. I assume the best way to measure would be between u-joint 'ear' centerlines.
Chris
Chris
turbo z (05-21-2023)
That number rings a bell. Thanks. About 10-12 years ago I swapped a T56 from a 95 Camaro into my 88 using the standard T56 bell and it fit the same. or very close to it, as with the 700....so I concur.
JamesC
1 Post
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
Hope this helps. I have a 350 with a th-350 with the short tail shaft and my 41 1/4" driveshaft wouldn't work, so a guy that does this for a living, made one for me 45" long, which fits perfectly. I was told to measure with 3/4"-1" of the yoke extended from the seal in the housing.
Eric86TA (01-17-2022)
i have that same prob I removed my v6 with the 4 speed and installed the 350 with th350 short shaft and my driveline is too short at least 2 inches so your saying if i have mine lengthened to 45 inches it will fit?
1 Post
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
I am saying mine fits perfectly.To be sure for your car,insert the yoke to within 3/4" fully inserted and measure from the center of the yoke u-joint to the center of the rear u-joint and that his how long of a driveshaft you need.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The proper measurement is:
Install slip yoke into transmission all the way. Pull back out 1". Measure from center of slip yoke u-joint to center of diff u-joint. That's your driveshaft measurement.
i am new to this sort of thing and maybe you already answered this but i have an '88 Camaro Base model w/ 2.8L v6 . i am attempting to convert to a borg warner WC T5 and would like to know if it can be done without having to change out a ton of stuff... if there is an easier solution any help would be appreciated
Car: 1992 firebird
Engine: 3.1.... soon to be... bigger.
Transmission: 700r4, looking for t5
Axle/Gears: I havent a clue.
I just put a w/c t5 (from 95 camaro 3.4l) in my car (3.1l) and used my old 4l60 shaft, it fit- but i had to pry and wedge it in
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Just wanted to throw this in, when measuring for driveshafts, make sure the rear suspension is at ride height, and not full droop.
Yes it will work, I just put a single piece Dr shaft in my camaro. I had this same problem just day before yesterday. And instead of putting that 2 peace back in, I put a single Dr shaft from a firebird. Don't second guess your self, just go for it.
Drive shaft help.... saw a lot of knowlegeable people...
When you say,
"thirdgen shaft is 41 1/2 from center of the U to center of the U"
Please define "center of U"
I took that to mean the hole where the cap / u joint end is on the drive shaft....
When you say,
Engine: 4++,350 & 305 CIs
That is a late 4th gen driveshaft.
The "3rdgen" 1st design was made until at least 1996. (I have a 3rdgen one date coded 1996)
No. AFAIK, 3rd and 4th are the same length. I'm just identifying which you have.
Its a crime i'm sure you will get to the bottom of.
I can tell you I've had both side by side and they were the same overall length.
For the record...
The 3rd gen aluminum shaft IS 41.5
the 4th gen aluminum shaft IS 40.75
Over all, both are same length with slip yoke...
The 4th gen has a .75 inch balance on the yoke that the 3rd gen one does not...
When I replaced the yoke with balancer on my 4th gen shaft with just a yoke... it was .75 inches shorter...
#42
1 Post
For the record...
If you measure from the center of one U-Joint, to the center of the other U-Joint ("A" in the image below) yoke length would be irrelevant.
#43
Top is 4th gen with (shorter DS) with balancer on yoke...
Bottom is 3rd gen (longer DS) with no balancer on yoke...
Both WITH Yoke are same length...
But if you switch yokes... then one gets longer, the other shorter...
I have a 4th gen (shorter DS) and had to switch to a 28 spline yoke for my Astro A5 Trans (shorter) yoke... so my DS & yoke length shrank by .75 (the difference in shafts and the width of the balancer on the 4th gen one...
#44
Car: 1984 camaro
Engine: 2.5L 4 cylinder (151 Iron Duke)
Transmission: 4 speed Saginaw
Axle/Gears: 3.43
Sorry to bring this thread yo once again but i have a 84 with a 2.5l and a saginaw 4 speed. Im going to swap the saginaw out for a v6 t5 and im unsure of my current driveshaft length. Will i need a new driveshaft yokes etc? If I do or if i were to just upgrade would the fourthgen v6 2 peace be my bedt option for the vibrative 2.5l?
Vintageracer
09-24-2017 12:34 PM
no green
01-09-2016 09:22 PM
