clutchless
Old Oct 30, 2001 | 10:27 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
clutchless
well, its still here.. lol, i was in the highway (traffic), and right after shifting.. the clutch lost all pressure...you can tap it and see it wobble .. I then got out of the highway.. checked and noticed the 'shock' thats connected up the pedal.. wasnt connected anymore..
Is it just a C-clip missing ??
Old Nov 1, 2001 | 01:04 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Sorta, its not a "c" clip but a clip, very similar to the clip that holds the factory throttle cable on a carb setup, but bigger, has a tab to keep it on.
Old Nov 1, 2001 | 02:13 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I think Z28racer is thinking of the brake clip. The clutch pedal has a (white, in my case) plastic clip that "spaces and retains" the mastercylinder rod on the pedal.
The "shock" you're seeing is your clutch master cylinder (for future reference).
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Nov 3, 2001 | 04:18 AM
Spectre's Avatar
Engine: 3.0L/183
great ! Ill try that immediatly
thanks
Old Nov 3, 2001 | 03:12 PM
plain82's Avatar
I recently put a hydraulic setup in my 82, and the donor car had the same type of clip for the brake rod and clutch rod. The donor was an 88.
CodyP94
May 26, 2013 10:41 PM
S_Johnson
Nov 24, 2009 08:24 PM
noc_81
Mar 31, 2006 12:53 AM
Matto'85TA
Dec 24, 2003 11:17 AM
CrazyHawaiian
Aug 1, 2003 06:47 AM
