4th Gen rear questions
Old Jul 22, 2009 | 12:53 PM
c10crewchief's Avatar
Car: 1985 Camaro Sport Coupe
Engine: 355cid
Transmission: TH350
Axle/Gears: 3.73 Open Rear
Will the ring and pinion from a 3rd gen 7.5" work in the 4th gen rear? What size are the disc brakes on the 4th gen? I am currently running 14x7 rear wheels. And will a new prop valve work for the new disc/disc set-up if converting from disc/drum? I am sure all of this has been covered in various threads but I am new to the forum so please bear with me. Thanks
Old Jul 22, 2009 | 03:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th Gen rear questions
Welcome to TGO. A search is always a good idea here. As you can imagine there aren't many questions that haven't been asked. The following FAQ should provide much or all of the info you require:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
