Rear gears Question??
Old Nov 4, 2001 | 02:04 AM
Black91Z's Avatar
This is probly a dumb question but if I change my rear gears to 3:23s instead of my stock 2:73 will I need a larger carrier also?? this is what I've been told, I thought of going to 3:08s also I just want to go the economical route and keep the stock carrier..... Thanks for any advice
91 Black Z28 5.0 Auto.
T-top,factory cd player
All Stock
Old Nov 4, 2001 | 08:28 AM
GP406Z's Avatar
Car: 91 Z28
Engine: 406
Transmission: t350
I went from 273s to Richmond 373s (stock 7 5/8 10-bolt) and kept the stock diff.The ring gear is made thicker to avoid the use of spacers.
91Z28 406,mini-ram,Track-1s,232/242 roller,Wiseco 9.5:1 pistons,6"Eagle rods,Callies crank,Speed Pro EFI w/ wide band,Weldon 2015,Nitrous Express 150,Turbo350 w/ 10"ATI,12-bolt 373s,Southside bars,Centerline Warriors,28x11.5 ET Streets Best N/A: 11.22,120mph...10.41/129 with 150 shot
Old Nov 4, 2001 | 01:23 PM
Jay 727's Avatar
For whatever it's worth I installed an auburn limited slip made for 2.73 and up gears and retained my original GM 3.73's.
Old Nov 4, 2001 | 03:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
<font face="Verdana, Arial" size="2">Originally posted by Black91Z:
</font>
Hey fellow SoCal'er! You can buy special 3.23 gears made for a 2.73 posi unit. But if you're getting stock gears from another car, you need the posi unit too. Your best and easiest solution is to get a set of 3.23's or 3.42's off a 4th genner, and the SLP take-off posi unit, and the correct speedometer gears, and have that installed. The SLP posi is a 3-series and will bolt right into your car with the 3.23/3.42 gears.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 4, 2001 | 04:11 PM
Jay 727's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
Why does auburn sell posi units for 2.73 and up ratios? No special gears needed. It seems to me I could install 2.73, 3.08, 3.23, 3.42 and 3.73 with my carrier, so why are you saying he needs special gears. Just wondering....
Old Nov 4, 2001 | 04:14 PM
Kevin91Z's Avatar
Really? Maybe they changed something. I've always known that 3.08 and lower is 2-series and 3.23 and higher is 3-series and you cant mix and match them.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
