TC lock up switch
Old Nov 5, 2001 | 02:35 PM
cobrakiller1989's Avatar
TC lock up switch
What is the purpose form this? How is it used? Why is it used? How do i know if i should make one? do you need them on a computer controlled car with a lock up converter?
I guess that about covers everything i can think of.
Thanks ahead of time for any help
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis sturt tower brace
Old Nov 5, 2001 | 09:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It causes a direct drive action that acts like a manual clutch would.
How is it used?
It is engaged by the ECM depending on throttle position, RPM, speed, engine load, and the gear that the tranny is in at the time. I.E., it works in every gear except 1st.
Why is it used?
It reduces the RPM level at cruising speeds while under light load. It reduces engine wear, tranny heat, and increases MPG.
Your car had one from the factory. If the TC that you are using has the lockup feature, then the ECM is already doing it for you. That's also if the "Modded 700-R4" that you have also has the switch in it.
If you do a lot of highway driving, then it is a good idea, for the reasons I posted above. In stop-and-go driving, the lockup feature does very little.
I believe all the aftermarket switches only lock up the TC in 4th gear.
Hope this helps a little.
AJ
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford Punch 100. 1 - MTX 12" sub
[This message has been edited by AJ_92RS (edited November 05, 2001).]
Old Nov 6, 2001 | 10:03 AM
BlackBird305's Avatar
if your talking about the tech article on making one (ALDL lock-up switch) i highly recomend it...i've done many passes with and without the TC locked up and the avg was a 2mph gain and about a tenth or so...it really does work...don't leave it on though it will build up excessive heat in the TC
Old Nov 6, 2001 | 04:19 PM
AJ_92RS's Avatar
Oh, That. Wups.
AJ
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
SG91camaro
Sep 5, 2015 10:27 PM
luvofjah
Sep 3, 2015 07:08 PM
Slush92RS
Sep 2, 2015 08:56 PM
