T5 swap-what to do with TC lockup?
Old Nov 6, 2001 | 03:44 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
In planning my T5 swap for early next year everything seems straight forward except for what to do with the Torque converter lockup. Is this something that is easily bypassed or will I be needing a chip for a manual car?
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Nov 6, 2001 | 08:28 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Just coil it up and zip tie it to something. You don't need a new computer. The auto ECM will run a T5 car fine. I only swapped the correct ECM later because it was a free direct swap and allowed me to have the shift light come on. There are small differences in the advance table and fuel tables between the two ECM's, but it will run fine. The computer still thinks it's locking up the TC, but sice there isn't one hooked up, nothing happens. There isn't a sensor for the ECM to check for TC lockup, so no worry about seting a code. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Nov 6, 2001 | 10:52 PM
leirch's Avatar
Like Lon suggested, I would tie the plug up away from everything. BUT, I would DEFINATLY get the correct prom or memcal for your new transmission. The IAC movements and operations are WAY different. Trust me. I've been fooling with prom buring and have tried several things. You can drive it with an auto chip and it will run pretty well but it won't feel "right".
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Nov 6, 2001 | 11:41 PM
86Chicken's Avatar
I can attest to the "not feel right" principle. The idle speed when pushing in the clutch was really strange. It seemed to hunt around for idle for a few seconds then drop to normal. I put the manual prom in because this was bugging me and it fixed it.
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Gutted Cat, No muffler
Was 700-R4 --> Now T5
**** Great cars aren't bought, they're built ****
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
illegal87
Mar 29, 2001 07:38 AM
