strange sound when holding gear shifter.... help
Old Nov 6, 2001 | 11:29 PM
NXS055's Avatar
ok, its a 92 RS 3.1 5spd
when i change gears. if i put pressure on the shifter in the direction of the shift.. like pull it too far back into fourth and hold it there... then let out on the clutch to keep goin it makes a growl, grind, type noise, but quits when clutch completely engages....
does this in all gears, but not all the time
what is the prob???
Old Nov 8, 2001 | 04:39 PM
crucial's Avatar
Well you're pushing on the shift forks more then necessary making the gears mesh harder with each other. Therefore you'll hear a louder whine. Mine does that too so I make sure that after I put in gear I dont push on the shifter any more then necessary
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, aluminum driveshaft, WC 5-speed etc
red90IROCls1
Aug 25, 2015 06:56 AM
Out-Cast
Aug 22, 2015 07:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
killer777
Aug 8, 2015 02:47 PM
