how to line it up????
Old Nov 8, 2001 | 11:13 AM
speedfreaker's Avatar
im putting my rebuilt transmission {700r4} it was a pain to get out and it is turning out to be the same way to get it back in i have the car jacked up like 2 ft and i only have a 2ton jack and my bro's help to get it in how do you guys do this we got the bell housing about an 1 inch away from the block but it wolnt go anymore all help appriciated thanks
CHRIS
1983 firebird transam
edelbrock performer rpm intake 360*k&n intake 160 theroostat gitting trans raced up and lots and lots of plans 4 the future
Old Nov 8, 2001 | 11:22 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
Yes, I would like to see what someone has to say about this too. Is it worth paying a shop 3 hours worth of work to swap trannys?
To my knowledge, aftermarket stereo's, speakers, sub-woofers, and amplifiers will NOT make your car faster. As much as I have become attached to my thirdgen, it was only bought out of nescessity after my 1981 ElCamino SS was totaled in a rear-end collision. After nearly two years, I have yet to see a dime from the insurance company. RIP Elky (1981-2000)
Old Nov 8, 2001 | 12:34 PM
bhaas's Avatar
The easiest way to get it in is to get 2 long bolts, cut the headss off of them, screw them into the block. They make excellent guide pins. Slide your tranny in on those, put a couple of bolts in, and take the long ones out and put the rest in. Piece of cake.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Now has T5 in it. YES!!!
CenterForce Dual Friction Clutch.
Old Nov 8, 2001 | 03:28 PM
SoCo80p's Avatar
this is a pain in the *** , but done forget the front end is up and at an angle, so you need to angle the trans up a bit, line up the **** on the block to the holes on the trans and bring it home, the first swap i did took me hours, the 2nd i got it right on the first time, shouldnt be too hard, getting it in with 2 people is really needed
Old Nov 8, 2001 | 05:12 PM
Pro Built Automatics's Avatar
If it will not move any further, then the torque converter has moved forward on the splines and the converter hub is not lined up with the rotor. Take the transmission back down and reinstall the TC correctly, DO NOT FORCE IT, it will break the rotor and possibly other things in the front pump. When the TC & trans are installed correctly you will be able to spin the TC to line up the bolts for TC to flexplate. I repeat DO NOT draw it forward like would with a stick trans, the trans should be flush with the block when you install the case to block bolts.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
