BEST GEARS ¡¡¡¡
Old Nov 10, 2001 | 05:29 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
BEST GEARS ¡¡¡¡
GUYS NAME YOUR BEST GEARS PLEASE :
DRAG RACING / 1/4 MILE :
DAILY CITY DRIVER :
ECONOMY GEARS:
ROAD RACING :
STREET RACING:
HILL DRIVER LIKE SANFRANCISCO):
HIGHWAY DRIVER :
Please tell me what u like more cause im new into gears and now my drive pinion and ring broke up im learnin a lot on this
thanks
Old Nov 10, 2001 | 06:22 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by sammycalderon:
DAILY CITY DRIVER :
ECONOMY GEARS:
ROAD RACING :
STREET RACING:
HIGHWAY DRIVER :
</font>
Drag racing 1/4, the lower the gear the better, but it has to be matched to your powerband, if you can't rev past 5k rpms, you won't want 3:73s or numerically higher.
I would go with 3:42s for the most of them, but if you want economical on most stock cars you'll want a lower numerical gear like 2:73s.
But in the end you'll want gearing to match the setup of your car and your driving distances. If you do a lot of highway driving, go w/ 3:42s, if acceleration is what you want go with 3:73s as long as your car won't run out of rpms at the end of the track.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 10, 2001 | 07:29 PM
82camaro's Avatar
Car: 82 camaro SC
It depends on the car's setup and engine specs. For example, on a high performance engine 2.73's and overdrive, mileage will be worse than 3.42's.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
