Help!! Which rearend is better?????????
Old Nov 8, 2001 | 05:58 PM
hot89camaro's Avatar
I am looking into a ford 9" rearend for my car. I am shopping around, and have found a complete kit made by moser engineering, which is a bolt in, and a kit from curry enterprises, which is also a bolt in. Both kits come with axles, gears, center section, brakes, and housing, and run around 2000. Has anyone bought one of these kits? If not, which is the better kit to go with. I am open to all arguments! Thanks for the help guys!
89'rs
400 Small Block
10.2:1 AFR Heads
427 hp, 454 ft/lbs
Old Nov 8, 2001 | 06:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've seen them both. The only real difference is how they mount the torque arm. The Moser mount is very beefy but the Currie mount is more simplistic. Both will work the same.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Nov 9, 2001 | 08:24 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I have heard of problems with the Currie 9 inch because the case twists (torque arm mount is not strong enough). With ~450 lbft though, I think it would be fine though.
I put 520 lbft through my stock 9 bolt (well near stock 9 bolt ) I think I can make it last with maybe 550-575 with some of the new parts I'm working on.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
Old Nov 9, 2001 | 04:04 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
88 427... You say you have 4.10 9 bolts for sale? Does this include the posi unit? Is it the whole axle assembly?
Lastly, how much money?
I am in need of a new ring and pinion and posi and am looking at all my options.
Old Nov 10, 2001 | 11:34 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I don't say, I do have 4.10 gear sets and series 3 posi carriers for 9 bolts. These are brand new pieces.
I am working on a web page for all the info and all the other 9 bolt hi-performance stuff now (from gear sets to ). e-mail me for more info.
Miles
www.koolmeister.com
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
