I've been SHAFTED!!!
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
all th700r4 transmissions use the same driveshaft yoke, they are a 27 spline tailshaft. The input shaft is the only one that matters, and basically the older ones have 27 spline as opposed to the newer 30 spline ones. There are two input shafts, I'm not sure which one it is, but you'll know you have the newer type if you have a 27 and a 30 tooth, like mine did. I suppose the older ones have the smaller and the larger input shafts with 27 spline on both.
Car: 82 camaro SC
The splines you are talking about are on the input shaft of the tranny, have no effect on the driveshaft splines. All 700r4 driveshafts interchange.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
dbrochard
Oct 3, 2015 12:43 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
