Weird noise coming from my T-5
Old Aug 2, 2009 | 10:11 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I have been driving around and my T-5 seems to make a slight grinding noise when its in gear not moving. It sounds almost like im trying to shift into a gear without using the clutch but really faint/light. I replaced the throwout bearing about 30 miles ago when i put my new motor in.
I dont get any grinding from it while sitting in gear and the car is moving. Also it only does it in 1st thru 3rd from what i can tell.
Thanks Chas
Old Aug 3, 2009 | 12:17 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Weird noise coming from my T-5
I'm not sure when they switched to a hydraulic clutch setup, but if yours is a linkage setup you should check the free play of the clutch pedal.
Have someone run the car with the grinding sound and try to listen under the car (to the best of your ability, don't hurt yourself) and determine whether it's coming from the clutch or transmission.
Old Aug 4, 2009 | 04:08 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
mines hydraulic clutch. any other ideas? The sound doesnt happen when its going into gear just when its in gear and not moving.
EDIT: This is also behind a 383 if that matters.
theshackle
Sep 17, 2020 08:26 AM
pimp2303
Jul 27, 2017 02:03 PM
xxx3man`
Sep 23, 2015 10:37 PM
Cacike
Aug 27, 2015 05:10 PM
gwade12
Aug 8, 2015 08:17 AM
