transfixleo: troubleshoot for lockup
Old Nov 14, 2001 | 03:29 PM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
I checked the coolant lvl, my engine isn't missing, and my tps is new. I had a 5.0 L in my car but the engine blew so I have 5.7L now. The car had the same problem then as it does now. But I can feel the lock up in second gear like the middle of it. Maybe this will help more. Do you suggest a manual switch for the lock up? and how do put one in? Any other suggestions? thanx
Old Nov 14, 2001 | 05:23 PM
transfixleo's Avatar
If you have access to a scanner you could look at the data to see what is really going on. It is possible that hte converter is not holding but you can try a switch in place of all that. What you need to do is on the tranny at the connector there is a series of letters from A through D What you need is a fused 12 volt supply to the A terminal and a switched ground control on the D terminal. If it won't work after that then you are looking at an internal problem.
seiplentz
Aug 19, 2019 06:02 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
racereese
Oct 3, 2015 03:46 PM
customblackbird
Oct 1, 2015 04:30 PM
