Downshifting when wanting to accelerate...
Old Nov 14, 2001 | 11:39 PM
ChevyLuva3's Avatar
Whenever I want to accelerate, I usually just floor it, then the computer tells the tranny to downshift (automatic apparently). Some other times I like to downshift it myself, then floor it.
1. Which of the following ways will you get you accelerating quicker?
a)Just floor it.
b)Having part throttle, then downshifting "manually", and then flooring it.
c)Taking foot off throttle, then downshifting "manually", and then flooring it.
d)Flooring it, and then downshifting "manually" (before auto does it for you).
2. Which of the choices that are above are worse for the transmission?
3. How do you like to accelerate, from the choices above? If you have another way of accelerating please tell.
Old Nov 15, 2001 | 08:23 PM
ChevyLuva3's Avatar
Old Nov 16, 2001 | 08:35 AM
ChevyLuva3's Avatar
AKA, which way do you downshift in auto? which way is best? which way would ruin your tranny more?
Old Nov 16, 2001 | 11:53 AM
chevyboy07 91's Avatar
the best way for the tranny in this case happens to be the best case to go "faster" than normal....Just barely have your foot on the throttle so that the tranny line pressure is up (meaning the necessary fluid for high rpm's is there) drop it in whatever gear it is you want and then FLOOR IT! If you have your foot completly off of the throttle then down shift...thats not good b/c there is no adequate line pressure or fluid circulating the tranny. Don't forget the TV cable is the "door" between the throttle and line pressure.
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
[This message has been edited by chevyboy07 91 (edited November 16, 2001).]
gta90
Sep 15, 2015 04:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
86White_T/A305
Aug 17, 2015 12:16 AM
