Opnions about positraction
Old Aug 6, 2009 | 01:37 PM
88onfire's Avatar
Car: '88 Firebird
Engine: 350 (340 Est. HP)
Transmission: Turbo 350 (1800 Stall Convertor)
Axle/Gears: 3.42 Posi/28 Spline/Alum Diff Cover
So in the process of upgrading my rear end (i'd love a 9 inch but cant afford it) i found this unit:http://www.ringpinion.com/ProductDet...px?ProdID=1185
I was wondering if anyone had used it and if any other opinions on which unit i should use?
i figured this along with some 28 spline axleshafts, new ring and pinion and a c-clip eliminator(or would i even need one?) should get me down the road with my 350 good enough to smoke any blue oval that comes my way
Thanks for your help!
And yeah i know i spelled opinion wrong, i caught it after i clicked post new thread
Old Aug 6, 2009 | 05:58 PM
big gear head's Avatar
Re: Opnions about positraction
The Truetrac is very popular with auto cross and road racers. It is smooth and gets you through turns better than most other differentials. It isn't the best for drag racing. I prefer the Eaton Posi for street/strip use. The Eaton Posi is $435 and the Truetrac is $390. These will fit your 26 spline axles. You will need bearigns and shims to install either one. They are $45.
Old Aug 6, 2009 | 06:05 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
also to stregthen....weld axel tubes around where tube meets center section (has only two factory spot welds), get the 28 spline axels, and a stud girdle cover with bearing press bolts on back. Run a good shock proof gear oil, and you should be fine for a lot of abuse.
Old Aug 7, 2009 | 03:12 PM
88onfire's Avatar
Car: '88 Firebird
Thanks for the help, i guess im going to have to do some more deciding.
84,86,88Z28
Car Audio
Mar 6, 2002 08:51 PM
elevario
Mar 26, 2001 07:44 PM
BLUE92RS
Oct 11, 2000 10:59 PM
