Pilot bearing?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Pilot bearing?
How should I grease my pilot bearing? It's already pounded in, should I fill the little space behind it with grease or just put a light coat around the needles?
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Pilot bearing?
No grease if it's a proper bronze bushing. If a magnet sticks to it, change it while it's still apart.
Car: check
Engine: check
Transmission: check
Re: Pilot bearing?
RBob.
Engine: 5.7L/350
Re: Pilot bearing?
This is correct if you're using the roller bearing style.
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Engine: 5.7L/350
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Car: check
Engine: check
Transmission: check
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: Pilot bearing?
its a bushing. iv always been told a bearing wont work, plus im kinda scared if a bearing goes then it'll take out the input.
