Tranny question
Old Nov 4, 2001 | 06:53 PM
Faught's Avatar
Tranny question
I've got an 85 firebird with O/D. The tranny doesnt seem to shift quite right and hangs up at speeds above 50, when it seems as if it should go into O/D.. Any suggesitons ?
Old Nov 5, 2001 | 05:50 PM
transfixleo's Avatar
Start here: To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
Old Nov 10, 2001 | 07:28 PM
Faught's Avatar
Thanks for the info, but you'll have to explain a little more.. what is the "D" button.You mean put it into drive?
Thanks again
Old Nov 11, 2001 | 03:22 AM
No, on the cable there is a button shaped like a D that unlocks it.
[This message has been edited by transfixleo (edited November 11, 2001).]
Old Nov 11, 2001 | 07:16 PM
Faught's Avatar
Ok...
Looking through my HANES book I see the "D" button. Now another dumb sh** quesiton. Where is the throttle plate, inside the intake? ( some call it the butterfly ) or am I way off. What is a good way to ensure its all the way open
Thanks again
Old Nov 12, 2001 | 04:47 AM
Yes it is the butterflies but just make sure that the linkage on the throttle body stops FULLY open, no wiggle (there usually is a little). If need be, you can bend the bracket to get that last bit of wiggle out.
Old Nov 12, 2001 | 07:07 PM
Faught's Avatar
TFL,
Thanks again,
I'll try to get to in tomorrow
Old Nov 18, 2001 | 04:51 PM
Faught's Avatar
TFL,
Adjusted like you sugested and it has helped a hell of a lot. I can run up to 60-70 with no vibrations,but it still doesnt drop into overdrive by itself. Any other suggesitons?
Old Nov 18, 2001 | 06:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Here is the "book" method w/ pics to help clarify. I have never had a problem w/ the "book" method, but I'm sure if Leo's method was worthless, he wouldn't reccomend it, so look at the pics, and try what he says. TV Cable
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
