RPM For Downshift?
Old Nov 18, 2001 | 10:42 PM
92RSB4C's Avatar
RPM For Downshift?
When does y'all's trannys downshift? I have a 92 RS w/ L98 and 4L60 and a posi rear. I think the TV cable isn't set right.
My Web Page Look Out!!! I got my driving permit!!!
Old Nov 19, 2001 | 12:49 AM
transfixleo's Avatar
Are you saying that when you step on the gas, the tranny stays in the gear you are in? Try this first: To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
If that doesn't help it may be in the VB.
Elephantismo
Feb 13, 2019 12:51 AM
tyeo098
Nov 30, 2015 06:27 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
