700R4 shift points
Old Aug 9, 2009 | 11:41 AM
70StingrayL46's Avatar
Car: 86 T/A T-top, LG4, auto
Engine: 305 LG4, CC Rochester 4BBL
Axle/Gears: also; 70 Vette, L46, 4 spd
700R4 shift points
Anyone have any idea's on how to adjust the shift points? My 700R4 is shifting 2/3 too late (too high a RPM) at WOT. Manual shifting obvisously doesn't help any because I'm not trying to get it stay in gear and shift at a higher RPM but at a lower one. The transmission is in good shape otherwise and shifts fine during normal driving. The only changes made to the drivetrain are a change from 2.73 to 3.42 rear gears but I'm unaware of how this could make a difference. Most of my other cars that I have worked on in the past have been manual transmissions so I'm a little out of my element here.
Old Aug 9, 2009 | 06:39 PM
Pro Built Automatics's Avatar
Re: 700R4 shift points
Where is it shifting now? And where do you want it to shift at? Dana
Old Aug 9, 2009 | 10:49 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
make sure that tv cable is properly set. i have the same problem. i drag raced mine for the first time and it didn't want to shift. cost me the race cause i was winning
Old Aug 10, 2009 | 02:37 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Mine will not shift 2-3 at WOT when the cable is too tight. Just a click or two to loosen it up worked for me.
Old Aug 11, 2009 | 10:40 PM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
you can't change individual gears shift points without affecting something else on an automatic unless it is computer controlled. you can make adjustments one way or the other to make things closer or better though. on a 700r4 the t.v. cable and governor springs/weights change the shift points. the t.v. is adjusted near the throttle body/carb, and the governor requires buying a kit for different springs and weights. both are easy enough though. NOTE"""""" there is a little spring that can be added to the t.v. and it can pull the cable more at idle and light throttle and collapses at wide open!!!!!!!!!!!!!!! a lot of people add this spring with a gear change....
Old Aug 12, 2009 | 09:42 AM
Currently it is shifting at about 4900 RPM at WOT. I would like that to be about 4400 or 4500...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
