10 BOLT 7.5 AND 10 BOLT 7.5 5/8 IS THE SAME ?
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Are this the same ?
a 10 Bolt 7.5 rear end
a 10 Bolt 7.5 5/8 rear end
Thanks ..i think the are the same but not sure
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes. The only difference is the slightly larger ring and pinion of the 7 5/8". Everything else is the same.
GM upgraded to 7 5/8" somewhere in the late 80's. The diffs are still called 7 1/2" 10 bolts.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Car: 87 IROC L98
No. F-body didn't go to 28 spline until 90. The 7 5/8" was offered just before that.
Just did some quick research. The 7.5" was dropped in all Camaros , probably Firebirds also, in 1985 for the larger 7 5/8".
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
