Drivetrain help with LT-1 swap
Old Nov 9, 2001 | 04:45 PM
90RSErik's Avatar
Swapping an LT-1 and T56 for the LO3 and 700R4 in my 1990 RS. What should I be looking for as far as driveshaft...in other words, can i re-use my current driveshaft, or will I need a 4th gen driveshaft, or a totally different one? Any help is appreciated.
Old Nov 10, 2001 | 12:05 AM
ScreaminDeamin85Z's Avatar
not sire if the lt1 sits back farther in the engine bay or not but i would guess that you would be able to use your stock one.
Brandon
"ScreaminDeamin 360"
1989 IROC 350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
T-56 ,McLeod clutch, LT4 PP
http://ScreaminDeamin.cz28.com
Old Nov 10, 2001 | 02:16 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Well, since the 4th gens and the 3rd gens use the same driveshaft (dimension wise) you won't need a new driveshaft - as long as you get the engine in the car in the right position..... I am not really sure about this, but I know a guy that has an LT1 in an 86 IROC and I think he had to do some work on the motor mounts to get it in there correctly.... I'll ask him about that tomorrow at our MN F-body Club meeting..
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 11, 2001 | 08:08 PM
90RSErik's Avatar
Thanks...looking forward to hearing what you find out!
Old Nov 14, 2001 | 01:54 AM
Speed Freak91's Avatar
Car: '91 Trans Am GTA / '06 Z71
Engine: L98 based- .060 over 350
Transmission: madd dog 700R4
Axle/Gears: .3:42
the guy that built my car has a LT1 in his '91 Z28 ( 11.4??/ in the 1/4 ) ...go to www.KYFbodies.org...look for red91z ...he did my work and lots of other club members too...
Old Nov 15, 2001 | 02:24 AM
Matt87GTA's Avatar
Sorry bout the wait on this...
I didn't really get a chance to talk with him much about his LT1s in his thirdgens (I guess he now has two thirdgen Camaros with LT1s....), but he said that he bolted his LT1s in with the stock location motor mounts and all. He did say that installing ones with AC will cause some clearance problems with the frame, but still get bolted into the same mounts as the stock thirdgen engine.... He also bought a Spohn transmission crossmember/torque arm assembly for one of the cars that also has a T56 in it. The other LT1 powered Camaro has a TH700R4... He used the stock driveshafts in both cars (I think he got a 1LE aluminum one for one of them, but it is still stock thirdgen/fourthgen dimensions.)
So I guess the answer is that yes, an LT1 can be bolted in using the stock engine mounts (and a modified crossmember if it is a T56 trans) and the stock driveshaft can be retained (or a stock dimension replacement one like a 1LE one...).
Hope that helps some....
If you want to contact him, he posts on the Minnesota F-body Club's (link in my sig) message boards under the name 'LT1Powered85Z'
1987 GTA L98 MD8
My GTA
Old Nov 20, 2001 | 07:51 AM
90RSErik's Avatar
Thanks....very helpful reply...i'll look into that minnesota fbody site
[This message has been edited by 90RSErik (edited November 20, 2001).]
colton_carlson
Mar 8, 2019 12:21 PM
usafirebird
Exterior Parts for Sale
Oct 19, 2017 02:00 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Ducati900ss
Sep 2, 2015 09:05 AM
cRoe4
Aug 7, 2015 08:46 PM
