Drving with lower Gears you make less RPMS ?
Old Nov 19, 2001 | 07:54 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
if i install 2.73 on my car at 60mph will i make less RPMs if i drivin a 3:73 ?
Old Nov 19, 2001 | 07:58 PM
Joshua Leslie's Avatar
yeah, it will make about 20-30 percent fewer rpm.
but it will not be as fast off the line.
Old Nov 19, 2001 | 08:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Driving with numerically lower gears, yes. 3.73's are lower than 2.73's.
[This message has been edited by Apeiron (edited November 19, 2001).]
Old Nov 19, 2001 | 10:05 PM
irocaz28's Avatar
so my iroc is factory equipped with 2.73, os if i want ot put 3.42 in i would jus have to buy the gears and installation kit not a new carrier right?
Old Nov 20, 2001 | 07:36 AM
82camaro's Avatar
Car: 82 camaro SC
2.73 and 3.42 have a different carrier.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 20, 2001 | 04:24 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
you can get 3.42s and lower in the 2 series, i'd rather just get series 3 and add posi.
<- look ma, 300
late model 91 rs, fully loaded, auto, t-tops, red leather, paint- gm red and yellow blend (light red), custom painted 16" Camaro rims
305 tbi flat base 14"x3" with K&N, hypertech chip, accel super stock plug wires, only use full synthetic oil and delco filter, 2 1/2" cat delete pipe, Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: New v-6 stang, 96 v6 camaro, totally killed '86 SC Camaro (305), 91 z 28 with 305
15.854@87.57 (I think I could have it 15.5 with good tires and two more runs)
next month: rest of ultimate tbi
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
draco
Oct 4, 2015 09:25 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
