9 bolt bw questions
Old Nov 18, 2001 | 06:17 PM
Momar's Avatar
9 bolt bw questions
I was wondering what all is involved in changing gears and carrier in a 9 bolt. I dont think I would trust myself doing it without being taught how to do it properly, but I would like to know what is done. I plan on putting new gears in mine when I can afford it. I have read that the axles unbolt at the end kind of similarly to a 9 inch, but what else is done. Also, Miles if you read this, what all is included in your install kit.
Ben
Old Nov 18, 2001 | 06:46 PM
SoCo80p's Avatar
you need things like a back lash gauge, marking compound and a few other things, a gear swap is one of those few things left for a pro to do.
Old Nov 19, 2001 | 07:15 AM
Momar's Avatar
I realize that it would be best left for a pro, but I wondered what they will be doing. I was wondering more about the process to removing and installing the gears. I was also wondering what is different between the b/w and the 10 bolt that causes the haynes manual to give some instructions on working on a 10 bolt but says that special tools are required for a b/w. There appears to be a need for special tools for both. Is there something specificly different about the b/w for them to say this or what. Thanks for your help.
Ben
Old Nov 19, 2001 | 10:48 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Included in the kit is all the parts you need for a gear and/or carrier swap. It does not include the tools (special or not) like a pinion depth gauge, inlb torque wrench and dial indicator with mag base. It is not difficult to do, but like anything else, you need the correct tools and knowledge. But, for ~100-150 you can have a shop install the parts. It will cost 3x's that to buy the correct tools.
Go to the library and get a Chiltons or GM factory manual for info on the 9 bolt.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
Old Nov 19, 2001 | 11:21 AM
Momar's Avatar
Thanks for your help guys. I have just learned so much the rest of the car in the last couple of years and it seemed like I hadnt really learned that much about that. I plan on having a shop do the gears, but I just wanted to know what I was paying them for and be able to make sure that they didnt bs me. I think I actually have the chiltons for it here if I can find it.
Ben
Old Nov 20, 2001 | 07:26 AM
Momar's Avatar
Well, I read the Chiltons. It showed how to remove the axles. Does the rest come loose when you do that. It didnt tell how to remove the rest.
Ben
Old Nov 20, 2001 | 10:53 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Try the library for their reference books. It has very good illustrations. I will try and scan some in too, but it won't be until atleast next week.
Miles
www.koolmeister.com
Old Nov 20, 2001 | 11:12 AM
Momar's Avatar
Thanks for your help, but I did go to the library.(The chiltons that I had was not the right one) I didnt find anything better than the chiltons but that is almost all I could find that even mentioned the borg warner other than to say (other than borg warner). That would be great if you could scan those in, and thanks for being so patient with me.
Ben
Old Nov 20, 2001 | 03:59 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You need to buy a Helms repair manual for your car. Either from ths link, or eBay.
http://www.helminc.com/helm/homepage.asp
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Nov 20, 2001 | 05:36 PM
Momar's Avatar
Well do they make them for multiple years because my car is an 85, the rear end is an 86, the tuned port is off of an 87 and will be converted to speed density which will be covered in the 91-92 manuals. Those books ar expensive and if I have to buy one for each year that will cost me quite a bit of money.
Old Nov 21, 2001 | 12:15 AM
lonsal's Avatar
The 86 rear and 85 vin are the same. Then you'd need to get the 91 or 92 for the SD. There may be minor wiring and sensor issues to deal with for the 87. But if it is just an engine no biggie. Too bad there isn't a library of them to check out. 8^) Pick up what you can cheaply on eBay.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
