Spec Or Centerforce?
Old Nov 18, 2001 | 01:48 PM
Yarnboy's Avatar
My centerforce just went out..Should I get another or go with a Spec or some other comparable brand? Is there anyone that has tried both? This clutch lasted me about 30k miles. Thanks alot!
  • Red '88 IROC 305 TPI T-5 w/3.08
  • Accel 300+ Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Dual Friction Stage III Centerforce Clutch
  • Energy Suspension Transmission Mount
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Gutted Airboxes
  • Hypertech Stage II PROM
  • Hypertech Airfoil
  • Throttle Body Coolant Bypass
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
I am looking for a 3.42 - 3.55 posi disc rear. cheesy@fred.net is my e-mail, send a letter if you can help!
Old Nov 19, 2001 | 11:30 AM
nestz28's Avatar
I don't know enough to go into details but just about everything I hear about centerforce is bad. Try going with a comparable McLeod clutch.
Old Nov 21, 2001 | 12:28 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dont think Spec makes T5 clutches, so get a McLeod.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 21, 2001 | 06:52 AM
poncho9789's Avatar
I know spec makes the star clutches for t-5 trannys they are some of the best clutches on the market. Most people I know go with the stage 2 or three.
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
