When do I need to change the clutch?
Old Nov 19, 2001 | 01:32 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
I bought an 88 Iroc 5 speed about 4 months ago, the guy said he just replaced the clutch, and I was just wondering how you can tell if you need a new clutch. Its not slipping or anything, but it is grinding into gears everyonce in a while. I just replaced the clutch master cylinder, so maybe I need more fluid? Any help..thanks
Old Nov 21, 2001 | 07:46 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
A small amount of grinding every once in a while is normal, especially when going in reverse.
Depending on the quality of clutch installed and your driving habits it will probably last you several years before it starts to get weak.
Your clutch will start slipping at high gears during acceleration first. As it gets worse, the slipping will occur in lower gears.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: TBI & Suspension mods
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Drone358
Sep 1, 2015 02:50 PM
Drone358
Aug 27, 2015 11:15 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
