manually shifting a 700R4???
Old Nov 21, 2001 | 11:53 PM
jptaylor2's Avatar
ive got an r4 behind a stout 383 and at the strip when in drive it shifts at 3700. as you can guess this is not good for low et's. can i adjust the shift rpm up to about 5200rpm or do i just have to shift it manually. also will manually shifting it have any adverse effects.
jp taylor
Old Nov 21, 2001 | 11:56 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You can adjust the way it shifts, but you'll have to play around with the governor. Also look at similar posts about shifting and follow transfixleo's method for adjusting the tv cable. Or you can manually shift as well, which I do. But be careful with a stock shifter not to slide into N.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
