ATTN: 700 Experts
Old Nov 21, 2001 | 08:14 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
ATTN: 700 Experts
I was looking at my old transmission compared to my new one. The new one is out of an 84 van without an ecm, the van unit seems to have more swithes inside it. Is there a different way I should wire my Lockup Harness I can't seem to get it to work. Thanks.
1984 Camaro Z28
"Beige Bandit"
Mods:
new 350
Ededbrock performer intake and 600 carb
Accel dist with Accel module and coil
Bluemax wires
AC Rapidfires
cheapie headers
full 3"pipe
Dynomax 2out muffler
700-r4
2k stall
3.73 Posi 10-bolt
boxed lca's
fiberglass hood
Blisteins all the way around
Proxes H4 Tires
235/60 R15 -front
245/60 R15 -Rear
No times, no tracks remotely close.
Old Nov 22, 2001 | 03:18 AM
transfixleo's Avatar
Just switch over whatever switches you have from the original.
Old Nov 23, 2001 | 12:25 AM
Engine: 4G63T
There weren't any switches or wires at all running into it all i have is the wires from the 4 pin plug runing inside and ending with electrical tape. The previous owner wasn't nice to it.
Old Nov 23, 2001 | 03:42 AM
What I would do is this: The '84's had terrible shift timeing so along with all of the other reasons for the TransGo Shift Kit (not Reprogramming Kit or Jr. SK)you need it to correct this. It will include coorrected shift timing for L/U. Now you have two options. One is to block off the solenoid and leave it to the TCC Shift Valve to control L/U or the other is to let the conputer still have control but the Shift Valve with make sure it happens at a proper speed. You can do this by bypassing the wiring internally and essentially connecting the A and D terminals in series with the solenoid. This way when the signal comes the solenoid will activate the circuit and at the proper speed it will L/U. If you do this W/O the SK it will not happen at a good speed and could bog the engine and if you block the solenoid it won't always unlock at times that it should and driveability suffers. It does work if you have a strong engine but it's not as good.
djmarch
Oct 2, 2015 10:41 PM
ASE doc
Sep 22, 2015 03:13 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
