Pwerglide OWNERS ONLY!!!!!!
Old Nov 22, 2001 | 01:22 PM
german-motorsport's Avatar
Anybody running a JW PG?
Does anybody has a dimesion pic?
Any pics installed in a 3Gen?
Is it wider than a tremec 5 Speed?
www.camaro-firebird.de
Old Nov 23, 2001 | 10:29 AM
TPI_Guru's Avatar
almost all automatics are wider than manuals due to the way they work in regards to design and gear changing
a powerglide is thinner than most autos though...so i'm not positively sure
i know a few 4th gens who were running powerglides but not a 3rd gen.
They are un-useful unless you have a lightweight vehicle turning high rpms or a 1000+hp car that needs the traction on a stock suspension
Old Nov 23, 2001 | 11:14 AM
Funny statment!
Well i guess you have never seen a JW!
And yes we know the fine line of usefulness!
PLS ! ONLY JW OWNERS!
Old Nov 23, 2001 | 07:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was going to go with a glide but decided on a TH400 instead. I didn't want to have to buy another shifter. The body of the glide is very small. If you really need a performance one, buy an Ultrabell case. A stock glide case will break if too much HP is put through it.
Since it only has low gear, direct and reverse, there isn't much inside it. Standard transmissions will always be smaller. Simple gears don't need as much room as clutchs, drums and hydraulics.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Nov 23, 2001 | 08:12 PM
TPI_Guru's Avatar
<font face="Verdana, Arial" size="2">Originally posted by german-motorsport:
Funny statment!
</font>
i worked at a trans shop for two years, i know what JW looks like
dont be so quick to judge
also, the JW case isn't that much wider than a stock PG case but the bellhousing IS
Lbibb
May 5, 2016 12:00 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
