quick governor question
Old Nov 23, 2001 | 06:50 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
the gear on my governor is chewed up, so i'm gonna replace it tomorrow. What is the gear it meshes with made of? Is it a metal gear or plastic? Since my governor gear was chewed, do i need to pull the tailshaft and replace the other one as well?
Old Nov 23, 2001 | 07:25 PM
Pro Built Automatics's Avatar
It is steel. Make sure you get the gear for the 700R4 & not the TH350. Otherwise you will be back in the same boat once you back out of the driveway (first & reverse only)
Old Nov 23, 2001 | 09:12 PM
TheWraith's Avatar
Engine: 355
whew...that saves me the headache of pulling the tailshaft.
I'm gonna actually grab a few governors out of 700r4's in a junkyard tomorrow so i have spare stuff. Never have this stuff when i need it. Do the governors vary at all by year of 700r4?
thanks pro-built
Old Nov 24, 2001 | 12:44 AM
transfixleo's Avatar
They vary by application, from the size of the weights to the tension of the springs.
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
