Switching from gear oil to ATF in T5
Old Aug 16, 2009 | 12:33 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Just got a T5. It's supposed to be an 87.
I drained gear oil out of it. Any problems with just re-filling it with ATF?
Old Aug 16, 2009 | 12:59 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Switching from gear oil to ATF in T5
If that year T-5 is supposed to run gear oil run gear oil. Only run ATF if the manual tranny calls for it. I have run ATF in a tranny that called for gear oil only to get rid of some varnish and clean it out real good. I drove easy and drained it out after 500 miles. That would be the only reason to put ATF if if it calls for gear oil. I dont remember what year they called for ATF in the T-5. I think it was 88 but could be wrong.
Old Aug 16, 2009 | 01:44 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
That's my point. I have no clue what it calls for and you'll get a different answer from everybody you ask.
Old Aug 16, 2009 | 05:52 PM
subroc's Avatar
Engine: 355 TPI
Found the post your looking for. I remembered right. Non-world class T-5s (87 and earlier) use 70w gear oil. 88 on (WC T-5s) use ATF. Heres the post.
https://www.thirdgen.org/forums/faq-...t5-fluids.html
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Exxon Limited
Aug 9, 2015 08:13 PM
