Needing help figuring out my gears
Old Aug 17, 2009 | 04:41 AM
jtlockwood88's Avatar
Car: 88 Formula 350 / 87 Iroc 68k miles
Engine: 355 / 355
Transmission: 700r4 / 700r4
Axle/Gears: 10bolt w/3.23 - 9bolt w/3.27
Hey guys i need help with figuring out the gears in the rear end of my car, ive checked to find the axle code with no luck. it does have a stamp on the underside of the diff thou, but i havent found anything about that, that would help. right now im running 245/60/14 wheel and at 70 mph its and 2000 rpm, if that helps anyone out
Old Aug 17, 2009 | 05:48 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Needing help figuring out my gears
Can you verify that the tach is correct?
Old Aug 17, 2009 | 06:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the 10-Bolt FAQ at the top of the page.
JamesC
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
