Trans not engaging at WOT
Old Aug 17, 2009 | 09:35 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
My dad just bought a 91 Z28 convertible. The trans shifts fine in all conditions except for WOT. Say you're doing a 30 roll and punch it, the engine will just bounch off the rev limiter and the trans will not engage. One you let off the gas and resume normal driving everything returns to normal......any ideas?
Old Aug 18, 2009 | 01:52 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: Trans not engaging at WOT
That almost sounds like at WOT it is going into neutral. First guess is the valve body is routing the fluid wrong
Old Aug 18, 2009 | 02:00 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
TV (throttle valve) cable out of adjustment possibly....mine did same thing...seemed fine when driving....full throttle....acted like it was in neutral....
Old Aug 18, 2009 | 05:53 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
hmmm, I wasn't sure if a TV would cause that or not, probably the first thing we should check. However, he said the shift points feel fine so maybe not the TV.
Old Aug 18, 2009 | 06:03 PM
Engine: L98 494hp
there is a tech article on main page, I THINK, with info on how to adjust properly.....
5spdcamaro
Aug 28, 2015 02:12 AM
mdtoren
Aug 23, 2015 12:52 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
