How much whining is normal for a NWC T5?
Old Aug 18, 2009 | 04:11 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Just finished my swap and the transmission whines pretty good, only while accelerating. It goes with the speed of the engine. I pulled away from somebody's house and they said they could hear it from the sidewalk as I took off.
I put ATF in it for lack of a clear answer on what it takes. Thinking about trying gear lube now, but I'd like to know if there is a serious problem here.
Old Aug 18, 2009 | 06:04 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: How much whining is normal for a NWC T5?
What all bearing and such did you put in when you installed it? What bushing? Or did you use whatever came with the tranny?
Old Aug 19, 2009 | 05:03 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
What do you mean? Did I open up the tranny and change the bearings before I installed it? No...
Old Aug 19, 2009 | 11:31 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I think hes about the pilot bushing and throwout bearing.
Old Aug 20, 2009 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd think the problem is more serious than gear lube if the whine can be heard that far away (no noticeable whine in mine at all using Mobil 1 ATF). I assume you threw in a pilot bushing?
JamesC
Old Aug 20, 2009 | 12:22 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
new pilot bearing and throwout bearing but that has nothing to do with it. The only time i hear the whine is accelerating through 1, 2, 3. (Not in 4 or 5.) Neither the throwout or pilot are are under any sort of use in these cnditions.
Old Aug 21, 2009 | 05:35 AM
Ludo's Avatar
Car: T/A GTA & C4 Vette
Hello
I'am having the same problem with my WC T-5.
Whining in the 1-2-3 and not in 4-5 gear.
Hope to get some info here.
Greetings from Holland
Ludo
Old Sep 13, 2010 | 05:39 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Bump =)
Old Sep 13, 2010 | 09:20 PM
big gear head's Avatar
Time to tear it down and rebuild it. These transmissions wear out the pilot bearing for the main shaft pretty often. I've had several do this. I think you might find that this is your problem. When this happens you must replace the input shaft, main shaft and the pilot bearing.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
thejimsterz28
Sep 30, 2015 08:52 PM
dusterbd
Sep 29, 2015 08:40 AM
Youngs92
Sep 23, 2015 11:29 AM
